d/w sensor and ds18b20
Guest Kuuno
hi
how many of you have problems w temp readings hanging in d/w sensor? I have few installations were the temp reading just hangs at one place. the sensor itself seems to work
i tried changing the temp change parameter t 0c so it reports every 4minutes and the report does come but if the sensor is hung at 15,1 then the report is between 14,8 to 15,2. Actual temperature can be 21
im not sure if it is the problem of temp. sensor or d/w sensor
any ideas?
Hi, i have another problem. My d/w sensor have huge battery consumption with ds18d20! Is there anyone had similar problem? thanks
/emoticons/default_icon_question.gif" alt=":?:" />
This sensors are driving me crazy with the latest beta version.
Temperatuur is not reported correct.
The status is not always showing.
In the 1.047 they did work fine.
Only option to get them work again is a reset of the module.
Guest Kuuno
    what do you mean by temperature is not reported correct?
    thanks
    Works fine here, on latest beta.
