Cam sends footage to HC2 ok, not visible via remote access
Software: 1.047
I have IP cam set up and its output video visible in my HC2 control panel locally (= HC2 can see IP cam ok).
I have remote access working fine: I can log in to my HC2 from outside my network, and see real status of devices/change statuses etc. (= remote access fine)
BUT when I remote access to the camera settings page, instead of the live footage, it displays the 'no_video' image:
If I then click this image to enlarge it,
to see if this works, I get a 502 proxy error.
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /cmh2/index.php.
Reason: Error reading from remote server.
(Camera is the one sold as the MiCasaVerde VistaCam, but as I said it works fine with the HC2 when I'm on the HC2s & its network)
Please advise.
My understanding of the camera view is that the interface accesses the camera directly. If you are outside your network you would need to expose your camera streams and enter a public address for the cameras.
I guess it would be possible to use some form of HTTP tunnel for RTSP but I don't think this is how it is done. If I was running the proxy servers to allow this I would not want anything but H264 streams. Not many of the cameras support this so probably not something that would suite all users.
Worth checking with support on this as I do not know for sure what the capability is.
Robert
