Fibaro Door/Window Sensor and External Button
Guest MrZ
Is is possible so use the Door/Windows sensor with both the internal (magnet) and external Button?
And be able to get events for them individualy?
Magnet for the Door
and a cabel and external button for a bell button?
(I also have a temp sensor connected)
If I remember well, you can only use as sensor or temp+external button
Sensor and Temp
OR
External contact and Temp
Works fine for the bell.
Other option is
Uni sensor
This one can detect to contacts.
Guest imparator
    Hi, enver
    is it possible to use the external contact in a intercom system.
    so i can choose the externel contact for the bell ?
    Sensor and Temp
    OR
    Other option is
    Uni sensor
    Guest MrZ
    What is the reason to have two endpoints then...
    Both external button AND door/window sensor
    If they are the same???
    This is a single I/O device.
    You can use it as door sensor or as a I/O sensor. ...perfect.
    Guest MrZ
    Yes it is a lovely litle thing...
    But in the configuration in my controller it shows endpoints
    - Door/Window switch
    - Tamper
    - Temparature
    - External Button
    That was why I ask...
    Would have been nice if it was possible to have the external input for a bell or extra window sensor
    Hi, enver
    Sensor and Temp
    OR
    Other option is
    Uni sensor
    This works fine.
    Check if there is no power on the I/O line.
    For the Fibaro Videogate you will need a extra association.
    Since it's not possible to choice the Door window sensor as a trigger.
    Guest imparator
    Please can you tell me how to do this ?
    Hi, enver
    Sensor and Temp
    OR
    Other option is
    Uni sensor
    This works fine.
