Push notifications on Iphone
Guest paogig
newbi here and first post on this forum.
First of all I wish to thank you very mutch for your work here, a sourceful of information and tips!!!
I am facing a lot of problems with push notifications: not always received from my Ios devices, but most of all I am not able to let my new Iphone 4 receive any push notification, even if it is properly configured in HC2....
Do you ever faced this kind of problems?
I am running on stable v 1.047....
Many thanks,
Paolo
paogig, apple got problem with push when they gonna fix problem it will start work again
Guest Lode
    Apple servers seem to be ok
    Guest paogig
    Thanks both for your prompt reply!
    A.Socha, do you have first hand news on problems on Apple Push server? It seems everything working fine on Apple side..... (unfortunately I can't test it with other devices....)
    P
    paogig, try send email if he works that mean that push should work too
    you can restart HC2 and then check push i think will be that same
    Guest Lode
    Email works, push doesn't
    Even after restart HC2
    Lode, so that must be apple problem
    Guest Lode
    A.Socha, I don't know and i don't know where i can check that.
    I can see servers all servers are running.
    Can you check that somewhere. ?
    Guest Lode
    So its not an Apple problem as i was already thinking.....
    Guest paogig
    ...mmmmm..... no emails.....
    I have noticed that on this phone no location indication is showed on the upper left side of the main screen....
    Guest Lode
    What do you mean by that ?
    Guest paogig
    Hi Lode,
    in other iphone that works properly, in the upper left side of the Iphone screen in fibaro application usually I see the place in witch the phone is localized (eg. "Milan", ect.)
    This doesn't happen in my new Iphone....
    P
    [ Added: 2013-03-17, 14:29 ]
    /emoticons/default_icon_mad.gif" alt=":-x" /> No push and no emails.....
    Is there a place where I can find the Ios devices coupling procedure with HC2?
    P
    Guest Lode
    I don't see it on my phone.
    Before i could see the location so i don't know what happened.
    Fibaro is working on an update for the iphone app.
    I suggest you write down your problems in the bugtracker.
    Did you make a scene for sending email or do you use the notify option from the device ?
    I tried both and they work.
    Are your user settings ok ?
    Please check your certificate by Apple... the certificate is not automatically renew...
    Guest Lode
    Sorry but how do i do that ?
    [ Added: 2013-03-17, 18:44 ]
    I receive push from other app's so what is going on here ?
    It's not for you
    /emoticons/default_icon_smile.gif" alt=":-)" /> Fibaro hat certainly a certificate by Apple for the Push server. I had this problem with another application...
    Guest Lode
    /emoticons/default_icon_redface.gif" alt=":oops:" /> ok, didn't know that.
    I don't understand why they don't do that ?
    In the meanwhile i've been reading how to renew your certificate for entreprises.
    Just a couple of clicks.......
    Correct me if i'm wrong.....
    Guest paogig
    Hi Lode,
    yes I am using the notify option from the device....
    About user settings.... this is my concern....
    But i see the phone on ios device list, and I have selected the phone to receive notifications... don't know what to think on this....
    P
    Guest Lode
    Did you fill in your email adres in the user settings ?
    [ Added: 2013-03-17, 19:58 ]
    This way ?
    Guest paogig
    Yes, looks the same....
    Nothing wrong with my old phone, but now even emails doesn't work....
    Let me check device set up....
    P
