A.Socha 133
WARNING!
Upgrade to Beta software cannot be reversed by standard software upgrade procedure. The only way to come back to official software is to use Recovery Mode, then use backup and upgrade to official software version. It is highly recommended to create backup file before attempting to install Beta software.
After update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
WARNING! In case of update from old, official version (v1.x), after that update all users will be deleted. Admin password will be reset.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.515 Release Candidate:
- Refreshing power consumption in room screen
- Marking device as dead in configuration screen
- Fixed devices parameters setting
- Added Lili
- Fixed communication with Z-Wave devices
- Added possibility to deactivate scenes written with errors that causes system problems (e.g. scenes with infinite loop and without sleep)
- Other minor fixes
Bugtracker tickets:
- 0000059: Open http proxy
- 0000281: Heating Panel does not send correct temperature (with x,5°C) to devices
- 0000290: Ikona temperatury ujemnej
- 0000311: Random Door sensors show as dead in GUI and recovers without any invervention
- 0000316: Battery amount not the same fibaro door/window sensor and included temperature sensor.
- 0000319: Panel ogrzewania przestaje działać
- 0000336: nieskonfigurowane urządzenia
- 0000341: Bad energy costs in energy panel header when switching from power usage to energy costs
- 0000354: Click on the wrench of a device from "Your House"-screen causes system to halt.
3.506:
- Changes in Energy Panel
- Power consumption options in block scenes
- Additional options in scenes
- Z-Wave tab in configuration
- Button to reconfigure all devices
- Actual power consumption in wall plug configuration
- Wall plug parameters template
- Fixed bug not showing device configuration when wrong parent ID (after old conversion error)
Bugtracker tickets:
- 0000180: Sensor DSB05
- 0000189: Nie można ustawić wideofurtki bez dzwonka
- 0000203: Power consommation describer in Dimmer is not possible
- 0000258: Powiadomienia
- 0000275: Missing wallplug icon
- 0000298: Power usage is not being counted at the top of HC2 interface (power usage next to Dashboard link)
39 answers to this question
