Aeon 4-1 RC 3.514
TANE
After the upgrade to the beta 3.514 RC added the Aeon 4-1 sensor (Aeon is connected to power)
All the sensors are detected correct
Motion sensor will not detect any motion with the default settings.
What do need to change to let the Aeon work with HC2 3.514
20 answers to this question
  • I think this is a firmware problem in the Aeon
    I did test this device in Homeseer and Vera...same problems also there.
    Latest Aeon Fimrware is 1.18 (aug 2012)
    [ Added: 2013-03-19, 22:42 ]
    Update:
    Option 4 is is Enable/ Disable the Pir
    Option is set to zero and you can't change it.
    Just to be clear you are participating in betas.
    i fully appreciate that but hey someone is testing these betas SURELY before release? and yes bleeding edge is risky but please play fair and at least hold a beta back until you THINK it maybe worth upgrading to!
    [ Added: 2013-03-19, 21:47 ]
    Update:
    not convinced! worked a week ago with the same firmware no?
    deanrparry, can you remove and add again that device?
  • deanrparry, can you remove and add again that device?
    If you like I can give you remote access..
    Remove did not help.
    Pir Will not work other options are working fine
    There are 3 associations groups HC2 is only showing the first one..
    I am now resorting to COMPLETE factory reset and upgrading to 3.514 before adding any devices then i can give 100% answer i will also attempt to use default parameters as per aeon labs multisensor manual as i know they work 100% elsewhere (not mentioning any competition)
    [ Added: 2013-03-19, 22:18 ]
    parameters are included in this pdf and are a great guideline for what hc2 should be setting!
    [ Added: 2013-03-19, 23:08 ]
    that was a waste of time aswell
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> no motion sensor (fact)
  • Good news.
    All the sensors are working with the following settings.
    Guest Kuuno
    since first RC release yesterday my 4.1 sensor reports all info ok
    last change was today at 14:00
    Good for you!
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> mine are still broken all 4 of them!
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> past caring now just not going to use them
  • Check the settings of my device..
    You need to add the option 4 and change the option 3 to something >15
    Good for you!
    Have you updated 4-1 sensor firmware already?
    Guest thales almeida
    For me only the motion sensor is not giving me the correct state. I think i'm missing any configuration, because when i pass in front of it, the led blink. Someone had this same problem?
    read my post if you got problem with device
  • I have added a second sensor to my network.
    All the settings are identical. The first one is working fine with all the sensor.
    second one the PIR is not working.
    both are external powered..
    Please check this since one is working fine…in think this is a software problem
    TANE, both got that same firmeware?
    TANE, can you pate all data like firmware library z-wave, sdk etc all info from adv settings
  • See the screen snaps
