Problem with scenes SOLVED
Guest sk8er000
hello,
I've update to 1.047 to 3.517 and something is working wrong..
for example i've this kind of scene to turn on the light on the kitchen in the evening with a FGS221 Switch 2x1,5kW:
Everyday at 18:00 (at exact time)
and
ligh 1 = off
and
light 2 = off
then
light 1= on
this simple scene was working well on 1.047 but now in 3.517 if I try to manually turn off the light from the switch the light turns off and immediately on again...If I deactivate the scene the light turns off..
Someone knows what's wrong?
thanks in advance
10 answers to this question
Check if autostart is deactivate.
Guest sk8er000
    if it's the field: "Start when Home Center 2 starts" yes i've tried to uncheck it but the problem remains..
    for the hc2 this scene means: at 18:00 when the lights are off turn on the light 1 and leave it on forever..
    I only need to turn on the light at 18 but I also need to turn it off manually later
    and
    light 1 = off
    and
    light 2 = off
    then
    light 1= on
    for Hc2 that mean (if scenes is active and checked option Start when Home Center 2 starts)
    if its 18:00 and light1 and light2 is turn off then turn on light1 on forever
    so if you turn off light1 and is still 18:00 then it's gonna turn on that light again
    Guest sk8er000
    and
    light 1 = off
    and
    light 2 = off
    then
    light 1= on
    understood but this scene was working with 1.407, I've unchecked option Start when Home Center 2 starts but the problem is still there. what's the right setting to turn the light on at 18:00 and have the possibility to turn it off manually when i need?
    thanks in advance and thank youfor your hard work
    sk8er000, can you go to that scene check option "covert to lua" and copy and pastle it here? (don't use save batton)
    Guest sk8er000
    i've tried again with more attention:
    if scene is active and "Start when Home Center 2" also now 12:38 so before 18:00 when I click save, with both lights off, light 1 turns on.
    then
    if I turn off the light 1 with light 2 on ---->light 1 turns off
    if I turn off the light 1 with light 2 off---->light 1 turns on and then turns on again
    here's the LUA (not saved):
    %% properties
    6 value
    4 value
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger();
    if (sourceTrigger["type"] == "autostart") then
    while true do
    if (
    ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "18:00") )
    and
    ( tonumber(fibaro:getValue(6, "value")) == 0 )
    and
    ( tonumber(fibaro:getValue(4, "value")) == 0 )
    then
    fibaro:call(6, "turnOn");
    fibaro:sleep(60*1000);
    else
    if (
    ( (currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) )
    and
    and
    or
    then
    ok use that code for lua scene it will work how you want
    Guest sk8er000
    Thank you very much, I'll try it as soon as I come back home and I'll let you know if it works!
    Just a question for the future:
    Is it possibile to make this kind of scenes with blocks interfacce?
    yes and no
    yes you can do scene in block but will work like your prv scene then you must covert it to LUA and then edit it (delete part with else)
    Guest sk8er000
    OK thank you for the tip, so next time I'll need something similar just create the scene in blocks interface, convert in lua interface and erase the part with else
    [ Added: 2013-03-21, 18:05 ]
    thank you A.Socha it works!
