Door/window sensor notification and release 3.517
Guest berga_s
I have updated from 1.047 to 3.517 and I would like to know if it's possible to mange the notification from door/window sensor just in case of violation.
I mean that I would like to receive the notification only if the door/windos is open and was armed. If it was not armed, no notification.
In the 1.047 there was the possibility to select the option "send in violaion", even if doesn't work becasue the HC2 was sending the notification even if the door/windows sensor wasn't armed.
In the 3.517 there is no more the option "send in violation".
Is it possible to receive the notification just only in violation case?
berga_s, in 3.517 you got scenes where you can check if branched and armed then send (email, push, sms) but you can report that on bugtracker
Guest berga_s
    Ok, I've open a report on bugtracert and I've tried to use the scenes as you suggested (one for each sensor) and seems to work. Tanks a lot!
