For me is a good working system very import and always when I'm away from home the things will go wrong…Sometimes you just need to unplug/plug the HC2….for this you need your domotica
If you are looking for a Hardware backup for you domotica system you can use a Vera 2, 3 or a Vera Lite as backup system.
Just include the Vera to your system all the zwave network devices will be transferred and you can use the Vera when your HC2 is not accessible.
With some basic scenes the main systems will work for 90%
Check e-bay, marktplaats
