Guest AxelS
Hi Forum,
does anyone get the Z-Wave switches from Merten running?
I´ve several 2 gang wall switches (Merten 505214), roller shutter, Merten Move and so on.
Running 3.517 on the HC2, when I try to add the switches to the system, HC found them but do not configure them probably (they are recognized as remote control 507219). I´m not able to set associations because the area in die config is empty.
Also I can not set parameters - seems that the buttons fall asleep the hole time or that the config isn´t saved properly.
What is the right value for the data type? 1d, 2d or 4d?
Thanks for any advice.
BG
Axel
15 answers to this question
