Turning off a pc using lua
Guest sk8er000
I've found in this forum how to turn on a pc using HC2 and is very useful!!
is there a way to turn off a device with lua?
I've found this scripts on the web:
Shudown on Windows:
Code: [select]
os.execute("shutdown %-s %-t 01")
Shutdown on Linux:
Code: [select]
os.execute("shutdown %-h now")
but os.execute is disabled on HC2
thanks in advance
15 answers to this question
Hi sk8er000,
you can use SwitchOff ->
and create lua script to use the SwitchOff embed web server :
Guest dsilletti
    Hi sk8er000,
    Cool!
    Something like this ...
    Best regards.
    Guest sk8er000
    thank you very much Krikroff!
    I'll try it as soon as i come back home..do you know something similar for osx or linux?
    Krikroff
    i have done something like this. Is that correct?
    the SwitchOff software is installed. web server running port is 8000, basic authentication set to User password. Its still not working. what is wrong?
    Just in case the firewall is turned of.
    Krikroff
    Hi, have you replace with your userid and password? Have you tried directly in a web browser?
    I have set the user to "User" and the password to "password".
    When i try to open the the browser from local computer
    i come to the switch of menu. When i use a remote computer and try
    i also see the menu. Portforwarding is open and firewall is turned off.
    I think i am doing something wrong with the code. Just to be sure. The code is lua option is checked in HC2 and also the "wait for anwser from remote computer is checked.
    Maybe it's the spelling? Can you show one more time the full lua code set on your hc2?
    Guest captainigloo
    With MCE Controler, it's easy :
    In Virtual Devices :
    Button Off:
    Button On
    Ping Main loop & Status Icon
    On OSX i just have a file "shutdown.php" on my mac with this code:
    <?php
    echo "Shutdown mac";
    $results = shell_exec('sudo shutdown -h now');
    and a restart.php:
    <?php
    echo "Rebooting mac";
    $results = shell_exec('sudo shutdown -r now');
    but I remember I had to play with user permissions on apache to allow the sudo from this script. Can't remember how exactly...
    ub
    httpSession =  Net.FHttp(Your_SwitchOff_MachineIP, SwitchOff_Webserver_Port);
    It works also fine with a computer name instead of IP adress.
    [ Added: 2014-02-28, 22:10 ]
    Hmmm, no. Sorry, it works in my imagination only.
    It seems I forgot to save the script. So IP adress is needed anyway.
    Krikroff
    It seems that I have the same problem...When I try in another browser the
    then my computer shut-down..but when try with LUA code nothing happens
    Please let me know if I done this correctly:
    Created virtual device and in the button code I put:
    %% properties
    %% globals
    httpSession = Net.FHttp(192.168.1.15, 8000);
    httpSession:setBasicAuthentication(User, pass);
    response = httpSession:GET("/?action=System.Shutdown");
    selected LUA code and then Saved
    Not working... What is wrong?
    It could be that the quotation marks are missing on IP or port?
    emariu, when you use that link from your smartphone PC is going down too?
    I give my own answer,this worked for me:
    httpSession = Net.FHttp("192.168.1.15", 8000);
    httpSession:setBasicAuthentication("User","pass");
    the quotation marks did the trick
    did anyone ever get this working? if so can you export your VD so I can have a look, I have tried everything and am still unsuccessful ...
