Andyman 0
Hi
After updating to ver 3.517 no scene with time or sunset trigger work. Everything worked fine in 1.047.
The scenes are build in blocks and testet, even converted to LUA and test but no diffrens.
I've read in other topic that blocks doesn't work in same way in new ver and that a solution was to convert to LUA and delete part of code after "else", I've tried it too but no improments.
Example of sunset in blocks and LUA. When Active it's not possible to switch off lamp at all.
Anybody that has an idea what to do?
%% autostart
%% properties
24 value
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
while true do
if (
( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == fibaro:getValue(1, "sunsetHour")) )
and
( tonumber(fibaro:getValue(24, "value")) == 0 )
then
fibaro:call(24, "setValue", "15");
fibaro:sleep(60*1000);
else
if (
( (currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) )
and
or
then
5 answers to this question
