How to wire up....
Guest Lode
Hope somebody can help me out......
I want wire up an FGS211 relay switch 3kw to a double pole switch
It is used in moist rooms....
This is the scheme of the wallswitch.
Like Normal switch
Guest Lode
    Many thanks Shad for your nice picture but can't get it to work......
    It's driving me nuts......''
    Guest simryc
    Probably it should be like:
    but you have mirrored picture of fgs? (N,L from left? normaly it is from right L,N,I..)
    strange the others don't work????? think you need to check which wires are live and neutral.
    if you want to isolate then the second but low voltage would be less expensive
    and as i said in last post associate the two but it is a mad idea to use two devices
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    Guest Lode
    Shad, Simryc, Robmac,
    Thanks again for helping me and especially the time you've been taken to draw these fine pictures.
    There's definitly something wrong with the wires.
    I just measured and found the live were it shoudn't be.
    Tomorrow i have a day off and then i will be able to sort things out first.
    Update tomorrow...
    /emoticons/default_icon_wink.gif" alt=";-)" /> (btw tomorrow i will receive my first fibaro wall plug, i'm very excited... took a day off for that, how crazy can people be
    /emoticons/default_icon_cool.gif" alt="8-)" />
    /emoticons/default_laugh.png" alt=":lol:" />
