Anyone any idea how I can manually wake up a door window sensor?
I just tried to reconfigure a door/window sensor from the advanced tab. The GUI tells me to wait for it to wake up, or to manually wake it up. So far so good.
I clicked the device. I opened it and clicked the internal button. I triggered the magnetic switch. I even saw a temperature changes on my HC2, so it must have been awake when transmitting that temperature data. Still, GUI shows it as "Not configured" and looks like it's still waiting for it to wake up.
It's quite annoying have to sit here waiting for something to happen, and not knowing when it will happen. Am I missing the point here?
Same way to add device.
    Thanks Shad. That worked for the door-sensor, but the temperature sensor still shows as "Not configured." See attached. Any further thoughts?
    No idea for that. I don't for the moment, I going to use one for swimming pool this week-end.
    rvorsten, go to adv setting device press "configure to factory settings" later do wake up it should be then ok
    Thanks. I "configured to default settings" now again (seconds attempt), added the device again (without removing it!) and now indeed the door and temp sensor no longer show as "not configured".
    It still puzzles me why it did not do it the first time I tried this.
    A.Socha: what is your answer to "how do I wake up a door/window sensor?" Surely, adding it again cannot be the answer to that, is it?
    press 3 times like when you add/removing device or wait 4000s
    button "configure to factory settings" get all configuration device that way it looking like new adding process w/o removing with that same nodeid and id
    Thank you. That worked!
