FGS211 - Parameter 4
Guest GG
I Was going to use my FGS211 switch to turn on my lighting in the drive way and automatically let the switch turn off the lights after a set time using parameter 4.
It turns out that maximum turn off time thet can be set is 2.55s!??
How is this supposed to be usable?
When would I have any use of a 3kW switch to turn off the load in just over 2 seconds??
Is this a configuration error in HC2?
I'm using HC2 with firmware 3.525.
Ulf
GG, press left button mouse on that value 0.2s and enter there your value then press save
Guest GG
    I'm sorry, I can't get that to work.
    I'm using Internet Explorer 9 and have also tried with Google Crome.
    Can't find anywhere to enter a value.
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    Edit: Parameter 39 is editable this way, I can enter a value manually, but parameter 4 does not accept any manual input.
    [ Added: 2013-03-30, 16:44 ]
    Do you have any more ideas how to solv this issue, A.Socha, or should I write a bugzilla report on this?
