Fibaro wall plug reset
Guest frankdew
How can I reset the Energy counter for the fibaro wall plug I want to reuse it for an other appliance but want to start at 0
/emoticons/default_icon_question.gif" alt=":?:" />
read manual
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
press and hold button when you gonna get 1 menu then release button and press it again
Guest frankdew
    I was hoping i could do this from HC2
    ThXs
    frankdew, from hc2 you can reset for all devices (configuration tab)
    Guest jrkalf
    AdrewAdamRobRonald,
    Could the settings be made resettable per device in the HC2?
    Taking in account that the actual overall energy use isn't reset in the HC2, because the energy has in fact already been consumed.. but just the global counter of the specific device?
    I think that's the detailed question at hand here. And I'd love to see such a thing
    Guest frankdew
    But energy consumption isn't reset, only the parameters of the device
    frankdew, not that option
    option "meter reset" is cleaning kwh for all devices in configuration (where is restart hc2)
    Guest jrkalf
    In firmware 3.517 and higher:
    Configuration -> Z-wave Network -> Reset energy metering
    thx jrkalf,
    Guest GG
    The problem is that resetting energy metering does not work.
    Last part of this bugzilla is about resetting energy metering doesn't work.
    GG, It's work how should be
    that button reset kwh on devices and look on your screen shoot it's 0 so it's work
    if you want reset history in energy panel do new ticket with request new function
