This morning I putted in place FGS211 for controlling light. I did that and everything went well. I went in parameter in order to say that it's for light control, not show child / slave module but in the dashboard I have the parent module and the child/slave module.
Do you know to setup this module in order to have only the parent module in the dashboard?
Thx for your help
Guest Lode
Did you save your settings ?
    Yes I did
    [ Added: 2013-03-31, 18:53 ]
    If I setup parent and child as light but with option "do not show child", I have only on device in setup view. But when I go into dashboard, I have two devices.
    Don't know if this is an incorrect that I did or a bug in dashboard display.
    Guest Lode
    Hmmm... strange.
    I tried it again (show/don't show) and that is ok.
    What version are you running ?
    Running 3.517 with FGS211 ver2.1
    Guest Lode
    The only difference is that i have FGS211 v 1.9.
    Really don't know what can cause this....sorry...
    Thx Lode for your help
    Pictures of setup view, can help
    Guest Lode
    I saw that parent and child have the same name, normally that shouldn't be a problem.
    Maybe renaming the child but in my case it does not help.
    Maybe in your version ?
    Reconfigure ?
    [ Added: 2013-04-01, 13:22 ]
    Do you still have that problem ?
    • 2 months later...
    Sorry didn't saw your last reply, yes still have this issue
    /emoticons/default_icon_evil.gif" alt=":evil:" /> .
    Now I'm running 3.458 and the problem is still here
    /emoticons/default_icon_rolleyes.gif" alt=":roll:" /> . Perhaps I will post a report on bugzilla
    • 1 month later...
    I have the same problem on all devices with slaves:
    not accessible in associations, neither in scenes.
