door / window
Guest nohed
Problems include Fibaro door / window sensor Hc2 can not find it help
nohed, devices->remove device -> try 2x 3 clicks till you don't saw info that device is deleted later
add device -> 2x 3 clicks
Guest nohed
    nothing happens no matter how I do it
    check battery. check housing, is led is working?
    Guest spazpeker
    I have a door sensor all seems to work including the temp sensor however the LED does not do anything
    spazpeker, wake up device then you will saw LED
    Guest nohed
    led glows when you insert the battery then the lamp goes out
    new battery
    on hc2 -> devices-> remove device
    then try press 3 times look on led he should glow and then try again 3 times
    later
    on hc2 -> devices-> add device
    Guest nohed
    later
    no it does not light up when you press 3 times
    Have you mounted the sensor or are you holding it in your hand?
    If not mounted you have to hold the tmp switch on the back all the time while adding the device by pressing the inside tmp 3 times.
