Auto light in Bathroom [LUA] [READY SOLUTION]
Have fun!
I changed it for global variable
Seems to work, I don't know what it will do when:
rafal.m,
I removed my doors from Alarm panel, but I still get notify on HC2 when it's disarmed. Any solution?
I also have the same problem, sensors removed from the 'alarm panel' keep notifying when they breach.
Change into a global variable and working perfectly.
can you post the version that use global variables here
But is not working perfectly, I don't have time to work correctly on it.
I think that global variable can hold only binary values - is this right ?
the script use
lastArmed = fibaro:get(doorID, 'armed');
which is a build-in function of fibaro I assume - it looks like that it return a date / time variable that is been used in the timeout calculation
(os.time()-lastArmed)>=timeToEnter)
is there a way to log the door close event and get the time stamp of it without to use the 'armed' functions
anyone ?
No you can set string value but the variable panel interface has "issues"
You can monitor the "Value" property in a scene to be notified and get timestamp. 0 == closed 1 == open.
changed - using now Global variables and not 'Armed' System
enjoy
Nadav
have this codes working for few weeks, loved it.
Now i update to latest beta version and its broken..
can sombody help me with the code, and settings of the door sensor and light dimmer ?
lots of problems with the latest beta this is almost my last issue
thanks already
if (fibaro:countScenes()>1) then
should be
if (tonumber(fibaro:countScenes())>1) then
hmmm change the line but stil no luck.
complete delete the scene , ad the scene again nothing...
also nothing in the debug.
checked the ID's they are 100% okay.
on arming or disarm the door ID switch to it.
[ Added: 2014-09-07, 13:13 ]
Went back to good old firmware again.
copy the code into it and scene is working like a sharme.
something is just wrong with the new beta. send it to a member of fibaro group hope they fix it soon
[ Added: 2015-01-08, 14:09 ]
a.socha helped with the code.
But what iff the door opens my child is sitting but not closed the door. She is finished goes out en closed the door. does the light stays on?
thanks
No problem, test the code of rafa half year now. It's perfect.
Your situation with child and door still open. Code see it as "cleaning" because a time of 10 seconds or longer the door is open.
when closing the door lights go out
one of the reason i called support , can't live without it
Top works great. only one issue more
what iff someone goes to the bathroom closes the door, finished, opens the door en whitout closing the door someone else goes in. then the lights goes off. do we nead a motion sensor.
thanks, also the children says thanks
That is indeed the situation, and i think only that the light go off, you always can toggle it manually for that time.
I have this scene, ground floor with our dutch small toilet
/emoticons/default_icon_wink.gif" alt=";-)" /> . It normal never happens except if some waiting while other comes out. But that is 1 of 100 for us.
It is also mind step, always close the door when walking outside.
Upstairs with our shower , in combination of toilet I got stevend smart lights, with motion (for me Aeon labs multi, i run nother scene also for a fan) and a dimmer.
That's a outstanding code. Use it with 3 scene's in the house
Then always light trigger on motion. I have several day type, and depending on that the light set's a dimm level. (handy for middle of night).
I'm just few months on the way with fibaro with small amount of devices but these scene's makes my day
This scene does not work anymore with 4.031
Do i mis something?
[ Added: 2015-01-13, 23:35 ]
Sorry, i use the new code writen by D-Vine and a.socha and now everything is ok again
/emoticons/default_icon_redface.gif" alt=":oops:" />
Have fun!
Have applied the above mentioned code in HC2 version 4.032. But not working
Any suggestions??
read page 3 good , you will find your solution
Have two lights in bathroom.
With door sensor want to operate each lights but individually in day and in night.
Ex. Morning 6am to 12am(First light) and Midinight 12 am to 6 am(Second Light).
Any suggestions??
at first I want to thank the topic-starter rafal.m for his code. Works very good
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> But I have a child at home, so the door sometimes not being closed. So I decide to add a motion-sensor in the bathroom in the code. I remove the manuel-switch. (The light doesn't switch off, when somebody is inside the room. Have fun
