Auto light in Bathroom [LUA] [READY SOLUTION]
Have fun!
Hi
after reinstall my doorsensor in 4.37 i get everytime ALARM panel.
when i open the door, wait for 15 sec and close. works great
when i open the door and closed, works great, but when i want out then it goes to the ALARM panel
wat must i change to wotk it again
thanks!
I see lookt and lookt never see it. but found it finally.
Have fun!
Thanks works perfect, is it posible to put in 2 lamps in the code? Please
Hello everyone!
I did not work the scene.
Forgive me for amateurish question: Do I need to be replaced   « deviceID»  in the line if (trigger['deviceID']==tostring(358)) then ?
Thank you!
You only have to adjust the id's in the following section, rest can be as is (so do not change anything else):
Nothing happens. Help! I do everything as written, but the debugger reports:
Kill second scene!
Help the confused please ....
Hi. How is possible to set the scene upstairs functioning only with a variable as sunset on?
Where is the line in lua you put new instruction?
Sorry for my ignorance...but lua is a problem for me
Thank you
I got this code for long time without any problems on 4.080
but with my parents HC2 and 4.081 nothing worked anymore.
now on 4.082 the scene only works as a light on (door sensor open) light off  (door closed) mode
any idea's ?
fibaro:call(lightID, 'turnOn');
fibaro:call(doorID, 'setArmed', '1');
fibaro:call(doorID, 'setArmed', '0');
-->> fibaro:debug('Light on!');
Replace with
fibaro:call(doorID, 'forceArm', '1');
made the changes test the scene and works fine again..
Thank you Kage!
