richo 4
Currently in order to build block scene that we want to run only manually you have to add a timer condition "Run once".
It creates a LUA code that in my opinion is to long and cumbersome. To avoid it you can create a Variable i.ex. "ManualScene" and set a value to "0".
To build a new manual scene you start it with a variable condition based on "ManualScene" - the code is simpler and easier to manage if you convert it to LUA.
