Latest version just been released!
But do not get over excited
This is not good...
Please check this..
Guest pablotibis
I configured the alarma home using the door / window sensors, I made 2 scenes "arm all sensors" and "disarm all sensors," in the interface for iphone see them in scenes, I can put them out in some way from home, as that is an option that I will use often and do not want them to mix with other scenes?
Wow, the new iPhone ap shows Camera streams again on 3G
It was a quiet solution of a problem by Fibaro but long expected...
Next problem is that the streams are very slow.
I hope Fibaro will fix this problem also soon.
Streams over 3G:
Direct acces 12 p/s
Homeseer 6 p/s
Vera 2 p/s
HC2 0,5 p/s
The problem is that the HC2 Dashboard, home AND iOS app render directly the stream of the camera, there is not proxy in hc2 between camera and the renderer. fibaro may integrate a camera proxy to handle request and perform encoding to deliver a Stream in adequation with the bandwidth but encoding is very loud in CPU usage ! My choice is to delegate this task to my home server and adjust the flow
Do you have also the probleme with virtual device who don't appear in the app???
I wrote to You also in iPadd topic
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> It is normal there is no virtual device in the iOS app, but I have heard they are working on that
