Just to be sure because I can't add it on hc2, I must:
- Disconnect power
- press B
- reconnect power without release pressing B
- wait 10 sec with pressing B
- disconnect power
- release B
- reconnect power
Because if it is that, he don't work for me
/emoticons/default_icon_confused.gif" alt=":-?" /> or UBS is dead
Guest dsilletti
- Disconnect power
- press B
- disconnect power
- release B
- reconnect power
For my 3 UBS I just did this:
- Disconnect power
- press B
- release B
- disconnect power
- reconnect power
Then I addes again to the HC2 controller, and all worked perfectly
regards
Domenico
    thanks I will try.
    Guest dsilletti
    - Disconnect power
    - press B
    - disconnect power
    - release B
    - reconnect power
    - Disconnect power
    - press B
    - release B
    - disconnect power
    - reconnect power
    Then I added again to the HC2 controller, and all worked perfectly
    regards
    Domenico
