[SOLVED]Scene With Condition
fxpa
Hi
I Would Like to create a scene but it does not works
The idea is :
Everytime when I start the scene, If the FGK101 of the garage is open, the garage Door must close.
Uploaded with
10 answers to this question
checkbox "start with hc2" is checked?
second condition is checed? (that part what you was cut)
Ta scene est bizarre, pourquoi dans la condition tu as le capteur en position fermé alors qu'il devrait être ouvert. Après pourquoi tu as un device virtuel et non le module de ta porte auquel tu dis de ce fermé.
In your scene is strange, why in the condition you have your windows sensor in close position because it must be open. After why do you use virtual device and not the device from your garage door which one you send order to close.
  • Hello
    The virtual device is a Http relay connected with a remote for my 3 gates
    The garage door system has no way to tell if is opened or closed so i've put a Door sensor to know the state of the door.
    I've create 2 scene, one for opening and the other for close the door
    The "open Scene" is :
    When I run it, if the door sensor is closed, use the virtual device to open the door
  • Go in lua code it is easy to do that.
    Yes May for those who know LUA code
    But My scene condition is so simple to not work with block scene
    Remove your timers and put the device you want click to do the scene.
    Guest jrkalf
    The last line of your scene in blockmode is a virtual device. Have you manually checked this device by pressing the button outside of the scene? Does it do exactly what you want it to do?
    Virtual devices can be tricky, it's wise to test them manually first to see that they're actually doing what they're supposed to do, before combining them into scenes.
    Try this code :
    You must change the ID of the door sensor 325 with your ID and the ID of the Virtual device 143 with your ID. "pressButton", "1" = Button n°1 of the virtual device.
  • The last line of your scene in blockmode is a virtual device. Have you manually checked this device by pressing the button outside of the scene? Does it do exactly what you want it to do?
    The virtaul Device works like a charm
    Problem is the scene don't care about sensor state and send the command
    [ Added: 2013-04-09, 08:10 ]
    Try this code :
    Tested
    It works
    Tks For ALL
    Now I've to learn LUA (VB.NET would better for me )
