Iphone App Req
- Speed up video over 3G (0,5 frame is just to slow)
- Auto detect network and select remote connection when there is a need.
- Show All the sensors in a room when a room is selected incl motion and Light Sensor
- For the Video gate there are is need for two clicks and Alarm is one..(make this configurable user can select what they want on the main screen)
- Show the weather conditions at home and not the one for the iPhone location.
- Add restart HC2 to the Config page
- Iphone 5 large screen support
- On the camera page also show the devices in this room.
- Display virtual devices
15 answers to this question
Guest Dennis
+infinity
Guest pablotibis
Guest Lode
+ Energy Panel
    + History Panel
    + Notification Panel
    + Heating Panel
    + Device include / exclude
    + Possibility to change camera order
    + Possibility to hide some rooms.
    + Change background color
    + Always online when active
    + Possibility to change the order of the device because not work as expected
    + Remove + & - buttons on temp & humidity sensor device
    Reduce the number of clicks (user configurable)
    For turning of the garden lights my clicks
    Current app
    1. Rooms
    2. Section
    3. Outside
    4. Second screen
    5. Turn off the light
    Request
    I will add all the rooms to the main screen
    Make icons small (blocks 3 in line not the long ones used for dimmers)
    1. Outside
    2. Turn off the light (9/12 Devices will fit in one screen)
    [ Added: 2013-05-08, 17:11 ]
    Access the HC2 via external Ip and port number
    This will also make the iPhone app work when Fibaro Home server is down.
    [ Added: 2013-05-12, 23:16 ]
    Last night I was playing with the iPhone app and somehow all the screens did go open at 01:00 h. Almost sure that I did not push the small icon at the top.
    This one is also very trick...so small at the top of the screen near the home button.
    Some extra notification will be fine when controlling all
    Something like are you sure
    This feature should be correctly set. In fact, the geolocalization with iPhone is really useless if we have to connect into the application and "remote access".
    Otherwise we can use the geoloc like the video on the fibaro website (I did with manual option, really this is not WAF [Woman Acceptance Factor]).
    Maybe on iPhone prefs, Fibaro can juste set "always use remote access" switch ?
    any news when the new iPhone app will be available?
    Guest Kuuno
    pretty sure after final ipad app and android app
    regards
