Strange DVR problem
Guest sk8er000
Guest sk8er000
I've got some ipcams and dvrs and I've tried insert some of them in the HC2..
my vivotek, aviosys, dericams and foscam work perfeclty but I've got a problem with iCatch dvrs.
I've found the right settings for here: www.ispyconnect.com/sources.aspx
If I go to the HC2's home page the miniatures work well but if I open the single camera the image stops
This is the link I use: cgi-bin/net_jpeg.cgi?ch=1 (1 is the number for the channel)
this is not a big problem but I'd like to know where I'm wrong..
thanks in advance
I have a similar problem with my IP cameras. Work fine on the homepage but clicking for a bigger image shows broken image.
It did used to work in older versions of the HC2 software.
