Wall plug energy reset
Guest Lode
Because i moved the fibaro wall plug to another device i want to reset the energy meter.
I just doesn't work.
I have an older Everspring AN 158 energy meter and that is set to zero......
VIII. Current load and energy consumption
Guest Lode
    Thanks, i was thinking that resetting the energy in the configuration panel resets all the meters but it's better this way. Even better is that you can do it from the hc2 UI.
