DSA22 Aeon Labs KeyFob (upd. - solved, working fine)
Guest shapa
Hi, today my HC2 system is arrived to me, I'm starting to play with (I've got a lot of devices (more than 60) connected to my Vera3).
Immediately I'm struggled with DSA22 device - it is added properly, but only one group is detected.
From the manual, I see that controller should switch the key fob to the "scene" mode as default mode is "groups" and "setup".
Could you please explain how to get some basic functionality, i.e. to trigger some scene via buttons?
FW is the latest one (3.544)
[ Added: 2013-04-14, 02:53 ]
OK, it loks like it is "simple" - I need to push config parameter 250 = 1
But I could not make any changes "(Waiting for Wakeup") status staying on...
[ Added: 2013-04-14, 03:20 ]
OK, I made it. After numerous attepts the keyfob received 250 = 1 and started to work in a scene mode.
Everything else is exactly the same to Aeon MiniMote - each button generates two scenes (short and long press)
Scenes are detected properly, no issues at all.
We could say now that DSA22 Aeon Key Fob is 100% compatible with HC2 (but configuration is not straight-forward).
[ Added: 2013-04-14, 21:40 ]
Real example
Short button press closing the garage door, long one - opening (bottom left button)
%% properties
96 sceneActivation
%% globals
local ButtonPressed = fibaro:getValue(96, "sceneActivation")
if ( tonumber(ButtonPressed) == 1) then
fibaro:debug("MiniMote button 1 pressed")
elseif ( tonumber(ButtonPressed) == 2) then
fibaro:debug("MiniMote button 2 pressed")
elseif ( tonumber(ButtonPressed) == 3) then
fibaro:debug("MiniMote button 3 pressed")
elseif ( tonumber(ButtonPressed) == 4) then
fibaro:debug("MiniMote button 4 pressed")
elseif ( tonumber(ButtonPressed) == 5) then
fibaro:call(102, "turnOff")
fibaro:debug("MiniMote button 5 pressed / Garage Roller Door Closed")
fibaro:sleep(3000);
elseif ( tonumber(ButtonPressed) == 6) then
fibaro:call(102, "turnOn")
fibaro:debug("MiniMote button 6 pressed / Garage Roller Door Opened")
fibaro:sleep(3000);
elseif ( tonumber(ButtonPressed) == 7) then
fibaro:debug("MiniMote button 7 pressed")
elseif ( tonumber(ButtonPressed) == 8) then
fibaro:debug("MiniMote button 8 pressed")
else
fibaro:debug("No response")
hi
the tuto is ok my keyfob work but every 2 ou 3 weeks i must reconnect the key fob on the hc2
because the are ne response
I did it and this work fine,
Tip for wake up the key fob: push learn bouton on back of key fob during 3 sec
