[solved] LUA script elseif is never triggered
Guest b95_lun
I have created a script to turn on a dimmer if movement is detected by PIR. The light should be turned on for 5 minutes after detected movement and if new movement detected during this period the coundown timer should restart at 5 minutes.
I two issues
1. Aeon-Labs PIR is set for a timeout period of 2 minues before OFF state is sent after being triggered (Parameter 3 = 120). This is very random in HC2 sometimes it takes 2 minutes but quite often it takes longer time.
2. In the script the elseif statement is never triggered. I want it to be triggered if an instance of the scene is already running (i.e. One while loop for the timer is running) and then I just want to set the timer back to 5 minutes and end the last instance. I want to have the first instance as the only controller of the timer.
Could anyone have a look on my script to see if I have made some misstake in the lua code?
Here is the debug from it and see that a new movement is triggered at 08:41:48 but it never enters the elseif.
As well the last fibaro:debug statement is never executed
[DEBUG] 08:39:24: start, timer = 0 lights = 0 ,triggerValue = 0
[DEBUG] 08:39:36: start, timer = 0 lights = 0 ,triggerValue = 1
[DEBUG] 08:39:36: Loop - timer = 4
[DEBUG] 08:40:36: Loop - timer = 3
[DEBUG] 08:41:35: start, timer = 3 lights = 20 ,triggerValue = 0
[DEBUG] 08:41:36: Loop - timer = 2
[DEBUG] 08:41:48: start, timer = 2 lights = 20 ,triggerValue = 1
[DEBUG] 08:42:36: Loop - timer = 1
[DEBUG] 08:43:36: Loop - timer = 0
[DEBUG] 08:44:59: start, timer = 0 lights = 0 ,triggerValue = 0
8 answers to this question
Guest jrkalf
    Don't run a script with if and elseif
    You have to run the check for seeing if this script is already running in the IF and use the ELSEIF for the actual script you're running.
    Elseif is only triggered when the IF does not apply.
    Guest b95_lun
    I finaly manage to find the mistake in my code.
    Thanks for you reply jrkalf but the issue was a misstake in the lua code. I have spent a couple of hours to find the issue.
    I hade used "." instead of ":" in the function fibaro:countScenes(sceneId)
    In my bad code I wrote
    and it should be
    I never got any error messages it just exited the scene
    ":" access instance function (you can use .self in the function -> this.) ex: in accessor functions (getters and setters). in clear if you have a member linked with the instance only function call with ":" can read the value... and Inside this function you use "." to call private members.
    See OOP (oriented object programming concepts).
    Many thanks for the scene - I was going insane trying to figure this out..
    But can you please add few lines (i'm not good with LUA).
    The scene should start ONLY when lights 199 and 146 (my ID-s) are turned off. I do not want to turn lights on 100% if the ceiling light is dimmed to 30% maybe or wall light is turned on already.
    Thank you in advance!
    Edit: It seems I do not understand the variable concept in this scene.
    local timer = "Variable_name" --Name of global variabel to control the timer <- What this should be.
    Scene works somehow - If light has been on for 4,5 minutes and movement is detected, then the light will work for 60seconds more - it doesnt loop the scene.
    %% properties
    199 value
    %% globals
    --199 = PIR for movement detection
    --Scene purpose
    --IF PIR detects movement then turn on dimmer and turn it off 5 minutes.
    -- If new movement detected during the 5 minute period set the timer for 5 minutes
    local sceneId = 57 --ID of this scene, used to detect number of instances run
    local timerEndTime = 5 --Minutes to keep the lamp turned on after PIR detects movement
    local timer = "Aeg" --Name of global variabel to control the timer
    local timerValue = fibaro:getGlobalValue(timer) --Current value of global variabel for timer
    local triggerValue = fibaro:getValue(199, "value") --Get PIR value that activated this scene
    local lights = 204 --dimmer to be controlled by this scene
    local dimmerValue = "70" --Ljusstyrka
    fibaro:debug("start, timer = " .. timerValue .. " lights = " .. fibaro:getValue(lights, "value") .. " ,triggerValue = " .. triggerValue)
    if (fibaro:getValue(lights, "value") == "0" and triggerValue == "1") then
    --If starts if lights off and PIR detected movement
    fibaro:call(lights, "setValue", dimmerValue) --Turn dimmer on
    fibaro:setGlobal(timer, timerEndTime) --Set global variabel for timer
    while (fibaro:getGlobalValue(timer) ~= "0") do
    --Loop used to control timer, each loop 1 minute and continues
    --as long as timer variabel isn't 0
    timerValue = tonumber(fibaro:getGlobalValue(timer)) --Get current value of global variabel timer
    fibaro:setGlobal(timer, timerValue-1) --Decrease global variabel for timer with 1 minute
    fibaro:debug("Loop - timer = " .. fibaro:getGlobalValue(timer))
    fibaro:sleep(60*1000) --Wait 1 minute
    fibaro:call(lights, "turnOff") --Turn dimmer off
    elseif fibaro.countScenes(sceneId) > 1 then
    --if scene is already running the set timer to 5 minutes
    fibaro:setGlobal(timer, timerEndTime) --set global variabel for timer to 5 minutes
    fibaro:debug("New instance, totalt = " .. fibaro.countScenes(sceneId))
    fibaro:debug("End, instances = " .. fibaro:countScenes(sceneId))
    Alusta
    Peata
    Tühista
    [DEBUG] 22:52:14: start, timer = 0 lights = 0 ,triggerValue = 1
    [DEBUG] 22:52:14: Loop - timer = 4
    [DEBUG] 22:52:16: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 22:52:29: start, timer = 4 lights = 70 ,triggerValue = 1
    [DEBUG] 22:52:31: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 22:53:14: Loop - timer = 3
    [DEBUG] 22:54:14: Loop - timer = 2
    [DEBUG] 22:55:14: Loop - timer = 1
    [DEBUG] 22:56:14: Loop - timer = 0
    [DEBUG] 22:57:14: End, instances = 1
    [DEBUG] 22:57:29: start, timer = 0 lights = 0 ,triggerValue = 1
    [DEBUG] 22:57:29: Loop - timer = 4
    [DEBUG] 22:57:32: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 22:57:43: start, timer = 4 lights = 70 ,triggerValue = 1
    [DEBUG] 22:57:46: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 22:58:00: start, timer = 4 lights = 70 ,triggerValue = 1
    [DEBUG] 22:58:02: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 22:58:24: start, timer = 4 lights = 70 ,triggerValue = 1
    [DEBUG] 22:58:26: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 22:58:29: Loop - timer = 3
    [DEBUG] 22:58:40: start, timer = 3 lights = 70 ,triggerValue = 1
    [DEBUG] 22:58:42: start, timer = 3 lights = 70 ,triggerValue = 0
    [DEBUG] 22:59:26: start, timer = 3 lights = 70 ,triggerValue = 1
    [DEBUG] 22:59:29: start, timer = 3 lights = 70 ,triggerValue = 0
    [DEBUG] 22:59:29: Loop - timer = 2
    [DEBUG] 23:00:29: Loop - timer = 1
    [DEBUG] 23:01:00: start, timer = 1 lights = 70 ,triggerValue = 1
    [DEBUG] 23:01:02: start, timer = 1 lights = 70 ,triggerValue = 0
    [DEBUG] 23:01:15: start, timer = 1 lights = 70 ,triggerValue = 1
    [DEBUG] 23:01:17: start, timer = 1 lights = 70 ,triggerValue = 0
    [DEBUG] 23:01:29: Loop - timer = 0
    [DEBUG] 23:01:41: start, timer = 0 lights = 70 ,triggerValue = 1
    [DEBUG] 23:01:44: start, timer = 0 lights = 70 ,triggerValue = 0
    [DEBUG] 23:02:11: start, timer = 0 lights = 70 ,triggerValue = 1
    [DEBUG] 23:02:13: start, timer = 0 lights = 70 ,triggerValue = 0
    [DEBUG] 23:02:28: start, timer = 0 lights = 70 ,triggerValue = 1
    [DEBUG] 23:02:29: End, instances = 1
    [DEBUG] 23:02:31: start, timer = 0 lights = 0 ,triggerValue = 0
    [DEBUG] 23:02:44: start, timer = 0 lights = 0 ,triggerValue = 1
    [DEBUG] 23:02:44: Loop - timer = 4
    [DEBUG] 23:02:46: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 23:02:58: start, timer = 4 lights = 70 ,triggerValue = 1
    [DEBUG] 23:03:00: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 23:03:11: start, timer = 4 lights = 70 ,triggerValue = 1
    [DEBUG] 23:03:14: start, timer = 4 lights = 70 ,triggerValue = 0
    [DEBUG] 23:03:44: Loop - timer = 3
    [DEBUG] 23:04:29: start, timer = 3 lights = 70 ,triggerValue = 1
    [DEBUG] 23:04:31: start, timer = 3 lights = 70 ,triggerValue = 0
    [DEBUG] 23:04:43: start, timer = 3 lights = 70 ,triggerValue = 1
    [DEBUG] 23:04:44: Loop - timer = 2
    [DEBUG] 23:04:45: start, timer = 2 lights = 70 ,triggerValue = 0
    [DEBUG] 23:04:58: start, timer = 2 lights = 70 ,triggerValue = 1
    [DEBUG] 23:05:01: start, timer = 2 lights = 70 ,triggerValue = 0
    EDIT2: NOT working still - went to shower and lights went off - I saw PIR sensor reacting many times during my presence but the timer was not restarted.. Help`?
    try this code. A bit different aproach but tested and working. Have to adapt to your needs and devices:
    Great, got it working, thanks alot!
    Guest dsilletti
    Hi Lauri, I'd like to use the same scene for my bathrooms, no more light switch off in the worst moments
    can you please share the final working code?
    Domenico
    Hi
    This also working
    %% properties
    xx value -- in this place please set ID "xx" your motion sensor
    %% globals
    local counter = 1800; ------------- this is time 30 min
    if (
    ( tonumber(fibaro:getValue(xx, "value")) > 0 ) -- in this please please set ID "xx" yuor motion sensor
    or
    then
    fibaro:call(yy, "turnOn"); -- in this please you have set ID "yy" your Relay Switch module, which connect the lamp
    while(counter > 0)
    do
    counter=counter-1;
    fibaro:sleep(1000);
    if
    tonumber(fibaro:getValue(xx, "value")) > 0 -- in this please please set ID "xx" your motion sensor
    then
    counter = 1800;
    fibaro:call(yy, "turnOff"); -- in this please please set ID "yy" your Relay switch, which connect the lamp
