ANDROID version
Guest Martial25
Guest Martial25
Fibaro team, are you currently developing an application for ANDROID?
We can not do without a version, even minimalist, but works in android
Thank
Fibaro team, etes vous en cours de developpement d'une application pour ANDROID ?
On ne peut pas se passer d'une version, même minimaliste, mais qui fonctionne en android
Guest eco-domodom
    Bonjour a toi,
    Je vais répondre en Francais puisque tu es français..
    Tu trouveras ici l'application en APK, à installer sur ton android.
    Cdt
    Guest Martial25
    Bonjour a toi,
    Cdt
    Merci mais elle ne fonctionne pas avec la version beta 3.544 !
    dès que tu clics sur Rooms puis tu choisis une pieces, ça plante.
    les icones sont uniquement des lits .....
    elle ne fonctionne vraiment qu'avec la version 1.047
    Merci quand même
    Guest jrkalf
    Pardon, the world none parlez French
    Could you please repeat it in English?
    Perhaps we can help?
    He said:
    Thanks but this one don't work with the 3.544 beta.
    When you click Rooms and choose a place, it stop to work.
    The icon are just bed.
    She only work with .047.
    Guest vedo
    It seems that everything is done for IOS but nothing for Android.
    The new HC2 version is not an evolution because Android APK does not work with 3.517 release it’s a real regression.
    Fibaro team you should not continue to work like this, if you make a stable version, you must provide a stable software for Android like IOS.
    Guest eco-domodom
    I'm home automation installer in France, and I would democratize the automation box, I totally agree with the previous posts.
    I also find that the development is in decline, functions disappear, an API is not stable, an internal clock unreliable, always bug the weather page. The android application no longer works. A translation into French with errors ....
    We must recognize that this is disappointing.
    For my part I have clients who asks me android app, I am unable to give them a solution with the latest version of the HC2.
    I am sorry for my English improved.
    I can confirm that android app works for me. Only problem is, that the icons of the rooms are all the same (bedroom). Otherwise everything works and I can use it allways.
    Did it work with 3.544?
    hello
    can anyone tell me if there is a working version for android.
    I have the 3.xxx version and the beta vesie no divices.
    This means that I do not have remote control.
    Is this normal??
    I have several times the software loaded.
    Whenever I go to the new versions, I lost my divices in android
    I have sony xperia go and android version 4.0.4 everything seems to work normally. I can turn on/off lights, run scenes, monitor my rooms..
    Whats the beta version you have in HC2?
    I'm using latest beta 3.544
    Guest thales almeida
    Lauri, do you have a roller shutter module installed? Beacuse here, I just can't access the rooms that I have roller shutters
    Lauri, do you have access through home.fibaro.com or android app?
    I can access both ways, no problems.
    And no - currently I do not have roller modules.
    Guest JURIS_S
    Maybe it will help Android development team to made something like VERA can do?
    Guest sk8er000
    Here's a developer that wants to integrate hc2 in his app:
    Guest Cirion
    Any news on the Android APP?
    Yes, on the polish forum we have read that NEW Android app should be ready in few weeks
