Dim level without turning on
I like to set the dimlevel of the kids room light after 21:00h to 30% without turning on the lights at that time.
When the lights turned on later so that it will start with 30%
In the morning set them back to 100%.
any tips?
4 answers to this question
Guest jrkalf
As far as I've seen it's not possible from lua code to "reconfigure" the device parameters.
Perhaps A.Socha has a trick up his sleeve?
    In the past I had a vb script.
    When the lights turned on between 21:00 - 06:00 hours they will be dimmed only once.
    With HC2 I have a build a scene to do this.
    Problem is HC2 will repeat the scene and will set the light also back to 30% when set manually brighter.
    I also mis the option between 21:00-06:00 h in HC2
    Or something after and before
    I did this:
    create a variable - night light - If light is low (below 20%) then turn variable to 1 otherwise 0
    create a variable - called night time. If time is 21:00 - 07:00 then variable is 1 otherwise 0
    created a scene - IF night time = 1 and night light = 1 and light is turned on, then dim lights to 30% and turn variable night time to 0
    It should be easy to do with lua, but i do not know how.
    @Lauri,
    Thank you going to try that..
