Http user:pass
need some help to get this lua script to work,
When entering the command line url without user/password it will work
The script will alos work when user/password is disabled at the destination.
plugwise = Net.FHttp("user:[email protected]", 8080)
response = plugwise:GET("/cc.html?applid=136&cmd=on")
fibaro:log(response);
Aslo no response with this
6 answers to this question
Guest deraaij
try:
    Mark,
    Thank you it works great.
    Guest deraaij
    Mark,
    You are welcome.
    Plugwise controlling via HC2 is now working fine..
    Next step is read the device status and usage
    this the XML file
    Hi, how far has this been integrated now including energy/gas? and is it easy to install in Fibaro? Also, you dont need the subscription of Plugwise when using this in fibaro? what about graphs?
    this the XML file
    it's time to create a plugin tane!
