After update of the iPhone app to the 1.6 in some rooms I find duplicate icons for the same switch.
In the H2C control panel I tried to move the switchs from a room to another but the duplicate icon remains in the iPhone app.
What is the problem?
8 answers to this question
can you do a print screen
    I rounded the duplicate icons. They are 2 icons but for the same switch.
    In the browser, instead, I see just one icon and it's right.
    piercar, can you close ios app and open it again and then check?
    I already did it. I also removed the app and installed it again. The problem is always present.
    Same problem here, running app on iOS 6.1.1. Resetting iPhone and restarting Fibaro app doesn't help.
    this could be a Channel 2 of the same device - check the names in HC2/api/devices.
    If this second device is in the 'other' it will not appear in the room.
    Not sure if this is your case but in my case that's how it is.
    I have exactly the same issue with a switch
    You can repair by changing the room number of the hidden device using virtual device with the following code where 99 is the ID of a hidden (double) device. It's usually ID of of a main Switch plus 1.
    To make sure check the parameters with http:///api/devices?id=99.
