The Cubieboard is a new Allwinner A10 based developer board, with a very wide range of IO options. The board is set apart by offering SATA and an extended pin interface for low level access to the SOC.
CPU: 1G ARM cortex-A8 processor
GPU: Mali400, OpenGL ES GPU
MEMORY: 1GB DDR3 @480MHz
VIDEO: HDMI 1080p Output
NETWORKING: 10/100M Ethernet, optional WiFi
INTERNAL STORAGE: 4GB NAND Flash
IO: 2 x USB Host, 1 x MicroSD slot, 1 x SATA, 1 x IR sensor
EXT INT: 96 extend pin interface, including I2C, SPI, RGB/LVDS, CSI/TS, FM-IN, ADC, CVBS, VGA, SPDIF-OUT, R-TP, and more
POWER: 5VDC 2A
/emoticons/default_icon_arrow.gif" alt=":arrow:" /> $49.00 USD
Wow !!!!
Thank you i Will take a look
