WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.545:
- Fixed displaying image from Home Entry System Helios.
3.544:
- Possibility to run scenes by Lili (please reload Lili database in configuration after update).
- Remote access scripts watchdog added.
- Added possibility to choose triggers in block scenes.
Bugtracker tickets:
- 0000487: Add/Delete GPS Points Error.
- 0000480: GPS condition doesn't work.
- 0000476: heating panel stop working.
- 0000460: Heating Linked Device fails to switch off Switch 2 (a.socha) - rozwiązany.
- 0000459: Modified variables don't show up in scenes.
- 0000454: Variables with space can't be changed.
- 0000437: EnergyPanel date select.
- 0000426: Option to deactivate variables as scene trigers
- 0000424: Bad slider position (cosmetic) in dashboard / actuator panel.
- 0000418: wrong foward for scenes to create new location.
- 0000403: headline.png not found in linked device panel (head of menu).
- 0000402: Unable to save new state of predefined variable value in dedicated panel.
- 0000396: translation in intercom panel.
- 0000387: Impossible to access the HC2 web page from iPad.
- 0000380: On the HRT4-ZW the temperature reading is being used as an energy reading.
- 0000369: Translation needed: Home Entry System Panel.
- 0000350: access right for users.
- 0000341: Bad energy costs in energy panel header when switching from power usage to energy costs.
- 0000331: Temp value of HRT4-ZW as energy usage in bar and panel.
- 0000328: Camera Panel when "Remote Access" is selected
- 0000288: SOme scenes can't be saved and disappear.
- 0000274: Modular Alarm Panel - iOs control and Users.
- 0000268: Modular Alarm devices can no longer be selected in Scenes.
- 0000245: no keyboard editting lua scripts via the iPad.
I would like to ask you on what are you working for make an update just for one thing
+1
update is in progress
its a joke sure
Guest jrkalf
Remember guys, This update is a "BLUE" update, this means it's a stable update.
So it's probably going from beta to stable with a minor fix to a panel.
Let's hope they update the beta REALLY soon™
I want my eversprings fixed
... and my aeonlabs smart energy illuminator
HC2 is getting better each new update, it is a pleasure ! Thanks Fibaro dev team
jrkalf,
2 Weeks to make a stable update for one thing, I don't think they are so bad developper to do that, they can make many release in one night so I am sure they make some surprise like Andrew said on other post.
Guest paogig
A.Socha, thanks for this "blue" update.
Lets hope remote access will work now, until I was under beta version it was impossible...
P
P
No problem here with the remote access and the beta's
Only problem is that not all the custom icons will show..
Updating..I hope the Video stream (Video Gate) is a a bit better…3G still to slow and not always showing.
Guest paogig
Wird, I have tried everything....
Thanks for your feedback, Tane
Paogig, you have remote access problems with iphone, android app? Or using home.fibaro.com?
Negative values ​​with aeon lab SEI are no longer reported in the panel energy (that is a good thing), aeon lab SEI does not work properly
IE 10 bug (as 3.544 beta): During update "download progress stay at 0%" (F5 works and refresh progress bar). work like a charm with Firefox
IE 10 bug (as 3.544 beta): cannot view event panel data
Guest paogig
Hi Lauri,
I had troubles both with iphone and PC.
with PC:
- first login ok;
- system selection ok;
- second login ok (on HC2);
- and then, this is what I see.....
With iphone, the HC2 information aren't loaded on the app...
Any idea?
Paogig
    paogig, do You have Internet Explorer version 8? Please update to newest version.
    I hope that this version is more stable than the 3.544... This version 3.544 was very unstable... I had to do a reboot every 1 to 2 days... (very slow zwave network after 1-2 days...)
    ikillou, do you got many devices? if yes change pooling from 125 to 300
    A.Socha,
    I have plenty devices and you have suggested to set pooling to 0 !?
    I did it and in general don't have many problems with dead devices...
    richo, in adv setting devices should be on 0
    in global configuration ->zwave
    125 -> default
    0 -> turn off pooling
    if you got a lot of reporting devices you can try other settings like 300, 500 or 0
    richo, Following the advice of andrew I have change the polling from 125 to 300 and now the dead nodes are very few (2 or3 per week) and i use lua code which monitor dead nodes every 30 minutes.
    U can try cut the electricity to the general counter few minutes, that help me when i had problems, it seemed to me that the HC2 re built the mesh
    /emoticons/default_icon_idea.gif" alt=":idea:" />
    Krikroff, our device got option dynamic re build mesh, others, dont have that option
    Guest thales almeida
    the helios 2n still not working for me. Someone did it work?
