Time difference
Guest Lode
Guest Lode
I have the following code that should do something between 23.00h and 05.00h but it doensn't work.
I think it has something to do because 05.00h is the next day.
7 answers to this question
and (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) and
seems missing condition operator like "==" etc.
and (math.floor(os.time()/60)-math.floor(1365541200/60))%60 == 0
i think you can remove that safety ...
replace or operator with and operator to check between 23H00 and 05H00
you can try something like that: (not tested)
Guest Lode
  • Hi Krikroff,
    Thx again.
    I tested it but it doens't work.
    When i try something like..... between 13.00h and 23.00h it works.
    I think comparing 23.00h and 05.00h (next day) is not correct.
    Lode, I think you should split the if statement like
    Lode, can you post your complete code ? and i try to debug it for you
    Guest Lode
  • Hi Gilbert, Krikroff,
    Thx again.
    Gilbert, i will try that tonight, i have to go to the dentist now
    /emoticons/default_icon_mad.gif" alt=":-x" />
    Krikroff, that was the complete code, there is nothing more.
    Greetzzz
    ok you can do that :
    it work very well for me
    /emoticons/default_icon_biggrin.gif" alt=":-D" /> hope this help you and tell me if it works for you.
    I put always
    to monitor script ignition, it help a little for debug etc. It's also good to break all conditions: step by step. You can remove all fibaro:debug("") inside the code after script validation ... good luck.
    Guest Lode
  • Krikroff,
    Thanks for putting all that effort in finding a solution for me
    It works but after device 22 is triggered there is a delay before the lamp turns on.
    I'll tell you what i exactly need......
    From sunset until 23.00h a lamp (id 27) is on at my slidegate.
    That scene runs fine.
    But suppose i come home (drunk
    /emoticons/default_icon_razz.gif" alt=":-P" />) between 23:00h and 05.00h and i open the slidegate, the lamp has to turn on immediately for three minutes when i open the gate.
    I have a universal sensor attached to the gate...breached by
    if (tonumber(fibaro:getValue(22, "value")) > 0)
