I've tried to add temperature sensors to two of my door/window sensors.
When installing the sensor it doesn't automatically turn up in HC2.
I've tried to remove one of my door/window sensors but now I can't ad it to HC2 again?!?!
the LED turns on and flashes like usually when adding, but HC2 can't find it.
Any advises?
Also I cant se the temperature from the other door/window sensor?
Guest skyhooper
You most mount the thermal sensor in the good Way , indications are bad, then when you add the sensor in the HC2 you will see the sensor like usual with an extra little box it took about 5 minutes to get the temp update and remplace that box.
I noticed that if the sensor legs are not connected correctly the Door sensor will show as a different device.
you must also delete and re add the device after adding temp sensor.
And the 3 presses need to be very rapid.
    I didn't have a problem adding the device without the temp sensor, but after I have deleted it it's not to be found again?!
    I've tried all I can think off. )c;
    Are you sure you have the temp sensor in the right way round?
    I made that mistake with one of mine.
    If you have a problem with reconnecting to the system the door / windows sensor you must reset this devices by removing the battery and insert follow the instructions. Next you add this sensor to the system.
