Mains power to Aeontec Multisensor
I want to mains power my Aeontec multi-sensor via the USB port. Does anyone have a solution to connect the USB directly to the mains not via a power socket adapter?
I want the cable from the multi-sensor to be hidden in the wall rather than having to add a power socket in the ceiling and connect the USB cable to a mains adapter like this one:
4 answers to this question
amilanov, i think the Right way is insert derivation box in your wall and connect USB adapter to main power and put all in the box: discrete, efficiently and you can use to power a cam or light above for example
Edit:
Or you can use something like that:
    Great suggestion. Cheers. I'll find a local supplier and get my electrician to fit it in a concealed box. I'll tell you how it goes.
    Guest jrkalf
    Like Krikroff states.
    I remember you were ordering JUNG switches.. They have this solution as well. Mine is getting build in next monday:
    Thanks, but I am looking for a solution that has the USB wire is going into the wall so that the USB connection is hidden. Although if I can’t find one I will just go for wall sockets like you have pointed out. Good tip!
    Also, the hidden option will be very cheap as I can use basic plastic parts, where as the Jung option will cost quite a bit.
