iPad app to write lua code for HC2
Guest b95_lun
Hi
Is there any possibility to use an external editor to write and test HC2 lua code?
I am asking because I think the editor in HC2 webgui isn't perfect. It works ok on a desktop but on iPad it is almost useless.
Is there any good iOS apps for lua coding?
Yes you can use LUA editor (pc version) to write LUA code with syntax color etc. but you can't test HC2 lua code because HC2 use proprietary libraries
/emoticons/default_icon_curve.gif" alt=":-/" /> write Lua script on soft and cut-copy to HC2 lua console to try it.
lua-programming xiaowen, touch lua, lua5 1.4, Lua console script, Lua coder etc. etc.
Guest jrkalf
    B95_LUN,
    according to the developers it's fixed in version 3.545
