Lauri 6
Hello, I'm trying to figure out a good scene to adjust the water temperature inside the underfloor heating system. There is 2 different heating sources - gshp and regular heating oven for firewood. This way the temperature that reaches the house might be different from 40C to 80C depends on which heating source is working.
Now there is 3way valve which mixes the temperature for the floors. Water temperature has to be always higher than 25C and never exceed 38C. I have connected roller shutter module to the 3-way valve motor, and it seems to work very good. But how can I make such scene, where HC2 measures outside temperature and also the water temperature in the pipe going to the floor heating?
The point is - IF temperature outside is 20+ degrees, then water must always be 25C; If temperature outside is +10C then water must be 28C and so on:
Does anyone have a good idea how to do this?
4 answers to this question
