sendPhotoToUser
I'm using this command for sending photo to e-mail
This works fine.
fibaro:call(91, "sendPhotoToUser", "2");
How to add the second cam number 178 to the the same e-mail
and how to adde a second user
something like this?
fibaro:call(91,178, "sendPhotoToUser", "2","3");
7 answers to this question
Guest jrkalf
This works fine.
I've sadly not been able to do so just as you want TANE. It seems that separate rules are needed, TANE.
There'll be a fraction of time difference between them
Can you save sendPhoto to a variable for each camera, then concatenate them together to get one email of multiple images?
Just how I would try to do it.
    @Jelle,
    thx
    The problem of separate is more e-mails for the same event.
    I have limited the number of e-mails but still to much when you have to send more then one.
    @Lockzi,
    I think this is not possible since you have to store images.
    Would be possible with small ftp and use script on raspberry example
    Can you better explain how to send images to ftp?
    thank you
    Normaly in you camera, you must have a link to capture picture, so you must get the picture with the link, then send by mail.
    Just do php script where you have;
    - get picture
    - select last picture
    - send picture by mail
    After, just but virtual device to call this php script.
    is the sendPhotoToUser function working still in v4 ?
    can't seem to make it work
