Guest Kuuno
i had this idea today and wanted to share to make it better and more advanced
basically sofar to control sauna one would add relay switch and use scene to star/stop the sauna? While it is not in the heating panel or similar it is little complicated.
you could make different buttons for temp and time to heat but still not so good i think
i though of using a dimmer module to set the temperature.
dimmer level sets variable value and then script is used to turn relay on/off
lets say 0% = sauna off
10% = 40deg
20%=50deg
and so on
this gives the possibility to control sauna from external wall switch also but the downside is no visual notification
any ideas?
