I needs HTTPS support - Net.FHttps ?
Hi Fibaro team,
I needs Https post
/emoticons/default_icon_curve.gif" alt=":-/" /> Is this possible and how to do this ?
Best regards.
[ Added: 2013-05-06, 21:01 ]
there is nobody here
Guest shapa
security is a "must" for many applications / devices.
BTW, I need to check what protocol used by iPhone app...
    I have open a ticket for request this feature
    Yep - I need this functionality also!
    Any update from Fibaro as to when it will be available?
    New about it?
    I need Https support to implement OAuth process, please
    regards
    Guest cedriclocqueneu
    +1, same need !
    Users, we are working for it, but all our programmers are busy on 4.X.
    Hello, yes I need it too !
    Isn't it a way to run a command such "wget" or "curl" from an LUA script to overpass the problem ? Assuming there is a programming gate between the OS and the scripting tool.
    Thanks,
    Thanks,
    Sadly blocked a few versions ago but not replaced with all the features needed yet.
    Aie, this is very frustating...
    is this coming in 4.x then..?
    V4 beta already supports HTTPS
    Works https !
    If so, what do I do wrong?
    I got this message: [ERROR] 17:34:42: line 6: attempt to call field 'FHttps' (a nil value)
    on this code...
    %% properties
    %% globals
    EliQ = Net.FHttps("my.eliq.se")
    response, status, errorCode = EliQ:GET("/api/datanow?accesstoken=secretbfc35789a321")
    jsonTable = json.decode(response)
    local power = jsonTable.result[1].power
    --local createddate = jsonTable.result[1].createddate
    --fibaro:debug(response)
    fibaro:call(635,"setProperty","ui.Label1.value",power)
    Scenes on v4 uses slightly different way to call HTTP methods, it was mentioned several times, e.g. here:
