Settings:
Parameter 1: ALL ON Inactive / ALL OFF Inactive
Parameter 14: Monostable
Parameter 15: Double Click ON
Using a double monostable switch/breaker
Why, when I doubleclick S1 (or S2 for that matter) does my lamp either turn ALL ON or ALL OFF anyways?
This is a short snippet from my scene, but I hope you get the point atleast.
Everything works like a charm, except that, when the lamp is on the correct level (same as configured dimmer-setting), instead of shutting the lamp off, it brings it up to 99% dimmer-level, and I get caught in my own script again
I don't want the dimmer to use the ALL ON / ALL OFF feature, I want to customize this using my own scenes instead.
What am I doing wrong? is there a setting I've missed?
If anyone can shine some light on the issue, I'd really appreciate it...
claymore,
I understand that you have device47 connected to S1 - correct?
parameter 1 (All ON/OFF) doesn't matter at all in that case.
If you use S1 with par 15 set to 1 it will have the priority to turn on the light at max:
"Double Click ON / OFF. Default Setting: ON (double click = lights set to 100%)"
With switch S2 and s2Double = 24 it should work. Have you tried different settings for par 41 ?
    Hi richo.
    With S2 double-click (ID 24), it works just perfect, but I have other stuff I want to do with that =)
    But, OK, then at least I know that it's pointless to get S1 double-click to work, or, that ALL ON always will have priority.
    Thanks for the reply.
