How to shutdown HC from remote?
I need to shutdown the HC from remote.
How can I do?
thank you
5 answers to this question
Impossible to do that.
you can do restart but shutdown is imposible
In the future, if this need comes up again, connect it to a fibaro wall-plugg, then you can cut the power atleast
Hello A.Socha. I would really like to know why? There are a lot of cases on the forum where people have problem with HC after a mains power cut. But if there is a way to programmatically (from LUA) shutdown HC it will increase the reliability of Fibaro HC and decrease both the number of tickets of data loss and thus the load on Fibaro support team.
As soon as the power cut is detected and UPS battery is low, we should have the possibility to shutdown HC in a regular "safe" way.
There attemps (take a look here
) to make a safer solution for power cut. But in case of a long power cut, without a shutdown it helps just to win couple of hours before "hard" shutdown of HC will happen which can cause the problem in HC.
I thought about the idea to open HC-box and put a relay that press shutdown button. But I don't like it, that is a hack!
/emoticons/default_icon_wink.gif" alt=";-)" /> I would really want to get a regular solution from Fibaro (at least a shutdown script).
I believe personally that Fibaro HC should have a small 5-minutes internal battery inside so it has enought time to shutdown itself programmatically in case of power cut. Maybe in future versions of HC?
all
can you please add this functionality ?
