I got a thermostat with accus, i want to replace it with a fgs211 or similar. But i have only 2 cable who go to the boiler. The boiler is for water and heating. I want the fibaro to control the heating with it.
What must i do?
thanks
Guest PJ
What kind of thermostat exactly do you have? Usually they are powered from battery and those 2 wires are used for turning on the heating (when closed) and turning off, when opened - in this case it's no problem to connect fgs211 (O1 and I), but you would need power source from mains to connect to L and N
    Oh ok, it's works perfectly! I understand now the system! The bridge was not clear to me.. Now it's cool.
    Thank you!!
