Record with Synology and virtual device
I want to start my camera when i go out just by pushing an interruptor. For that, i used the api of the synology surveillance station. It works from my pc but not in a virtual device. What's wrong with my code?
For starting record :
For stopping record :
thanks
perhaps, try to replace the name of your synology by his IP adress.
also, no login method to access to your synology ?
    Yes, you're right, there is a loggin method. You call this function :
    and it return a sid key, you can so send the action for starting or stopping the records :
    Can someone tell me how to get the sid key in lua code?
    Hello
    I did you get it to work?
