Scotfree 0
Wondering if anyone help. Trying to configure a variable change with the slave devices on the Aeon Multisensor, specifically the LUX sensor.
When I try to configure the scene and select the LUX sensor in 'Devices', it only comes up with the Master device which is the movement sensor and only allows it's parameters to be set (i.e. on/off/breached etc.)
Anyone know how I can select the LUX sensor so that if LUX <150 then change variable ?
Is this something I have to do with LUA because it is not supported fully by the HC2 ?
Thanks.
6 answers to this question
