Help. how to controle my reciever ?
Guest Dennis
Can some make me a right "code" to controle my onkyo Tx-NR609 true a virtual device?
i used the code of Krikroff and edit the ip and poort. but the command are not working.
so what is wrong? (but i gate the command "Command successufully transmited." )
my code: (power off)
Maybe 1 or 2 samples codes that are working right ?
THANKS
7 answers to this question
Guest MarkJ
    Did you find the solution?
    I tried it on my receiver but same result.
    Did you find a solution
    Br Mark
    Dennis, MarkJ, this code work great for me and friends for pioneer amplifier vsx and lx series. What's the command for your amplifier ? Can you send command to your amplifier via telnet ? This code open a socket and write to it but perhaps your amplifier not work like that.
    I have a complete virtual device to full control my pioneer vsx 2021k with auto update UI: zone, volume, selected input, processor, eq etc.
    Tell me more about your amplifier
    I have used the code as a base for a few devices but I change the
    to
    So I can make use of the new virtual device debug on the advanced screen
    Guest MarkJ
    HI
    I found this link to commands for Onkyo
    I Used "PWR01" to power on but maybe i simplefied it to much.
    Any suggestions
    It the good command
    /emoticons/default_icon_wink.gif" alt=";-)" /> , have you tried to send this command via telnet ? If it work with telnet client it must work with my LUA script!
    You can use on windows, open dos win cmd and connect to your amplifier with telnet
    Guest MarkJ
    Tried to connect to Amp but no succes
    I used
    o 192.168.2.xxx [60128]
    Answer is could not open connection to the host.........
    In debug mode the LUA code tels me command is send.
    Br Mark
    MarkJ, Check the port and perhaps you must enable remote support on your amplifier. (on the pioneer you must do that the first time in advanced menu of the amplifier after all work great, possible its the same on your onkyo).
    If not work from your computer with telnet command the LUA script cannot work
    [ Added: 2013-10-07, 23:47 ]
    Try with
    ISCP000000100000000701000000!1PWR010D
    Onkyo use ISCP, If it helps, the Onkyo command structure can be found here
    [ Added: 2013-10-07, 23:49 ]
    You can found information here :
    Keep us informed !!!
