Hi, I've designed and built a module which measures the intensity of light.
It works with UBS therefore there's no problem in communication with HC2. It connects as any ordinary temperature sensor, but in response we receive information about the light intensity from range of 0 to 102 (only integers) to ease the programming later. It's possible to connect up to 4 light sensors (can be mixed with dallas devices) to 1 UBS (the same as DB sensors).
1. Size and looks: a big bigger than UBS (see photo)
2. The measurements are reported to the UPS panel as a separate thermometer in celsius degrees, but it doesn't interfere with building own environments eg. in scenes.
3. It can take measurements inside and outside, the photo sensitive element is outside of the circuit board, so where we put it is up to us.
4. There's no problem with communication, HC2 sees it as an another temperature sensor in UBS panel, therefore no worries about problems with communication with the system.
5. Price, 20 euro + shipping costs
Feedback/questions welcomed
